Hello MM...again an update
Everything you have posted has been done and in a nutshell here is what was replaced...Dist Cap/ Rotor......Module...... Coil....Dist pick-up-coil was the last item.....
Put it all back together and "No Spark"
Very simply ......we found by swapping parts with the other engine and doing comparisons....I need not have bought any new parts.
We found the problem at the helm...
We disconnected the engine harness at a junction about 8 inches short of the ignition switch, did some wire jumping and found that when the key was turned we had 12V coming from the battery to the ignition switch but the moment we went to "crank' we lost about 4 to 4.5 volts going back to the engine with the end result of not enough power to bring up the coil. We also found that when the boat was built, the builders tapped off a few lines from the wire going from the ignition back to the engine when cranking. We followed a couple of the lines and found their connections on various parts of the instrument panel had come loose.
For me, the layman, the entire explanation was above my "pay-grade" but my mechanic ensured me that he can fix all the wiring, use solder instead of clamps, (apparently what the builder used), and we will have a serviceable system when he finishes the job Sunday afternoon.
Although I purchased electrical components that were not really required...I do have serviceable spares now and I was very relieved when my mechanic ensured me that the cables running in the raceway were fully serviceable and would not have to be replaced.
This was a very weird occurrence and 'normally' with "no spark" one would have felt sure that the problem was at the engine end, especially when it was proven that we had 12 V at the coill......but...as we later found out 12 V was not going back to the coil when we were in the 'crank' position.
I am sure that some of what I posted may be in error but based on what I was trying to glean from my mechanic.......we didn't have enough voltage going back to the ignition system when we went to the 'crank' position due to faulty wiring at the helm.
Hopefully my next posting will be my last and we will have a fully serviceable ignition sytem on that engine.
