What are your RPMs at WOT? If you're getting about 5000 RPMs, then your current prop is matched pretty well to your boat. Basically speaking, the goal is to get a prop that allows your engine to reach it's max WOT RPMs without going too far over or below the max WOT RPMs for your engine. With that said, my boat (see avatar pic) is a 17' v-hull that weighs about 2000 lbs. with the same AQ130/270 combination and it goes about 33-34 mph at 5000 RPM on flat water. I would not expect that sort of performance out of your boat however given its weight and hull type. A 15x17 prop will provide a little more top end speed at the same RPMs as a 14x15 would, but at the expense of slower acceleration. But again, the place to start is to see where your WOT RPMs are as compared to the engine's WOT RPM specification and go from there. A 2 pitch increase in pitch will decrease your WOT RPMs by approx 400 RPM and conversely, a 2 pitch decrease will increase your WOT ROMs by approx 400 RPM.
