Water pump
lelliott
"I replaced the water pump on
"I replaced the water pump on a DT200 Suzuki, now water is coming out of two holes near the front bolt on both sides of the lower unit , also the port side between the lower unit and the mid-section.. ????"
Probably the water tube which
Probably the water tube which inserts into the top of the pump housing was either not aligned when reassembling the gearcase or the rubber grommet that is fitted to the bottom end of the tube is damaged or missing. remove the gear case and check.
Good luck!
