  • Welcome to the updated forum! Existing members please log in with your current user name and password, or use the forgot password option. Visitors, please register to join in.
water damage on engine from winter staorage
sherricakes
My winter storage leaked and water sat in the hull and mold and slight signs of rust are appearing. How do I get all the water out? What is the best way to clean this up?
Troublemaker
Do you have a bilge pump and or a drain plug, if no then you will have to start bailing or buy a small pump. Once you get the water out, put a small heater in the engine compartment dry it out, a little elbow grease and a can of paint and you should be good to go.
TM
GotBoat
A shop vac that is rated for wet dry will help you out. You can clean individual areas out and it removes debris too. Depending on how much rust I would wire brush the rust, maybe use some CLR and lightly oil the metal when done or even paint it.
