" I have a 69 volvo 4cyl aq130
" I have a 69 volvo 4cyl aq130c. Over the winter I pulled the engine because one of the pistons was bad. I couldn't find the same size pistons so I had the engine bored 30 over. I installed 4 new pistons,rings,bearings and full gasket set. Then put boat in the water and it ran great for a month and now it is overheating before I back out from the pier. I installed a new t-stat and impeller for the water pump, still no fix. I checked the flow of the water pump and thats working fine. I don't know alot about this engine but any info may help or web sites I can look at. Thanks, Shane "
