Hello. I have a Mercruiser trim problem. Currently, it's stuck in the UP position. When I try to lower the trim by using the toggle down button, I only hear clicks. If I press the TRAILER button, I also hear clicks. When I press the trim UP toggle, I hear nothing. The does engine start.
I have checked all the connections around the solenoids, cleaned them up, & replaced the UP solenoid b/c it was completely black.
When testing the connections w/a voltage tester (which I'm not totally sure how to do): the only connection that I got a spark from was on the UP solenoid - and only on the smaller bolt to the top right, which holds a blue/white colored wire, which runs to the trim control wiring harness.
I've also checked & filled the power trim pump oil.
Please Help!
Please Help!
