Swapping relays produced the same conditionCheck relay(s) on lift motor unit on transom.
Check that one relay or the other @ the lift motor clicks when Up and down buttons are pushed. Yes, there is a limit switch. Usually at the top of the lift housing. PM me your email address and I'll send you a copy of the Volvo OEM shop manual which has the schematic.
Hello,would you happen to have schematic for 1970's single piston trim system?Thanks for the resolution report. All too often people fix an issue and disappear silently. Reporting the resolution adds to the knowledge base.
