scott_duerring
"I just put a brand new velvet
"I just put a brand new velvet drive transmission in. I also put in a new heavy duty damper at the same time. It is hooked up to a Crusader 8.2 fuel injected inboard. At idle it "rattles", not constantly but once every 10 seconds or so, if you put your hand on the transmission you can feel the vibration when it rattles. In gear at idle you can feel the vibration in the boat. The mechanic that installed the transmission thought the engine was missing so he installed new plugs, dist. cap and rotor. Didnt fix it. Once I speed up past idle then everything is fine. The idle speed is factory set at 600 rpm. The port engine is "rattle" free at all speeds. HELP???"
