I have a Tohatsu 9.8 HP 4-Stroke that I do not use very often - Probably 50 hours since new in 2006.
Yesterday, I put my dinghy in the water and the Tohatsu started right up. Let it run for 5 minutes or so and all seemed fine.
I pulled the safety key to shut it off and then restarted it. Started great.
Took the boat for a spin... probably 15-20 minutes without a problem.
Came back and pulled the safety key to shut it down.
Within a minute, I tried to restart and it would not restart - Choke off and throttle opened a crack.
Re-primed the fuel, made sure the fuel hose was connected properly on both sides, made sure the engine was in neutral, added choke. The fuel is fresh and the air inlet was open on the gas tank
Would not start. This went on for 10 minutes.
Figuring that I might have flooded it, I waited an hour and it would still not restart.
Boating day over.
Given that it had been running perfectly just minutes before it stopped running, I am confused?
This morning, I went to start it and it started right up. Now I really don't trust that it is dependable.
By the way, 2 weeks ago, I changed the motor oil and lower gear oil.
Any ideas?
Boating day over.
Any ideas?
