Hi,
I have a Tohatsu 50 hp, two stroke. It starts fine in the water; and runs very well. Then I stop and fish for a while. When I try to start her up again, it starts fine but has no revs. So, if you try to engage the throttle, the engine cuts out. Instead, I inch the throttle very, very slowly and eventually the revs pick up (say after a few minutes) and I head home with the engine in fine form.
I can't solve the problem; the mechanic said the engine is fine and the carbs have been cleaned. The fuel lines are fine and the battery is new. One mechanic said the problem is electronic, such as the rectifier, coils or CDI unit. But another mechanic said the problem is mechanical such as a head gasket slightly worn which is letting in moisture.
Any suggestions would be most helpful before we start more work on it.
Nollaig.
Nollaig.
