Misterrobot
Temperature Gauge an Issue? Try This:
The temperature gauges on my 1980 Gibson 42' Houseboat didn'twork. I figured it was like other marine gauges that work when theywant to.
For an unrelated issue I purchased a Johnson Pumps 10-24228-1 F5B-9 Crankshaft Pump to replace theoriginal raw water pump on the port side. The pump work so good about a month later I replaced the starboard side.
Ever since the replacement my temperaturegauges started working. Apparently thetemperature sensors on the 270 Crusaders need water to work! The engines run about 140 degrees.
The pumps move a tremendous amount of waterthrough the engines. The tone of theengines are lower are physically cooler than before the replacement.
I have received so much from these forumsthat I decided to contribute!
See you in the spring...
Capt. Ron
Mississippi River
Le Claire Iowa
Capt. Ron
Mississippi River
Le Claire Iowa
