M
marvin moss
Guest
"i have a 1988 dt20 3 weeks ag
"i have a 1988 dt20 3 weeks ago it would not start at all, after checking all the obvious, in my wisdom i took the fuel pump off checked and refitted. still would not start, made a cuppa pondered then tried it again and hey presto it started fine. we have used it twice since and the engine starts fine and runs at full revs for about 5 minutes then just dies to a tickover then eventually stops. i have found if i disconnect the fuel supply hose, there is no fuel in it. if i squeeze the bulb while manually operating the non return valve until i get fuel out, reconnect it starts and of it goes agin for another 5 minutes then same again. have checked all lines from tank to carb all seem ok, i am just thinking weather it may be one of the gaskets not sealed on the pump. any ideas would be greatly appreciated as most of our trips are night time.
thanks in advance"
thanks in advance"
