Hi everyone,
I’m looking for technical input and real-world advice on optimizing performance for my current setup, especially regarding propeller selection and RPM management.
Thanks a lot in advance!
My Setup:
- Boat Length: 32 ft
- Beam: 9.8 ft
- Total Weight: ~4 tons fully loaded (850L fuel + 250L water)
- Engines: Twin Suzuki DF300 outboards (2025 model)
The Issue:
I’ve tested multiple propellers and am running into problems with low WOT RPM and limited speed:- With a 3x16x20 prop, RPM drops dramatically to about 4900 at WOT, which is well below the recommended 5700–6300 RPM range for the Suzuki 300.
- I also tested a 3x15 1/4x19 and other similar sizes, but the top speed remains limited to around 75 km/h.
- A similar boat (same size/weight) but powered by twin Mercury 300R outboards with 22” pitch props achieved 100 km/h.
- Another comparable setup with twin Mercury Verado 300s reached around 91 km/h.
What I’d Like to Know:
- Is the Mercury Bravo I FS prop compatible with the Suzuki DF300 outboard?
- If yes, what hub kit or adapter is needed for a proper fit?
- What pitch and diameterwould you recommend for the Bravo I FS to:
- Bring the RPM back into the correct range (5900–6100)
- Improve acceleration and hole shot
- Push closer to the top speed that similar boats with Mercury engines are getting (90–100 km/h)
