Stern drive will no go up or down
rcmlittle
When I activate the riser the moter clicks but there is no movement. It is stuck in the down position. Is there a reset or what od I look at to help solve the problem???
Are you sure its the motor that is clicking or the relay? Relay is powered from the dashboard switch, but it switches +12 to the motor from the battery via a separate fuse...
