Steady alarm
jshane37
I have read the threads for disconnecting the tan wire on the horn, and disabling the sensor on the oil tank. Does anyone have a diagram that shows where the sensor is?
I don't have the diagram but the wire usually comes from the oil tank to the motor along with the oil line (hose). See where it enters the cowling and follow it to the disconnect point. Are you switching from VRO to pre-mix? You need to keep the temp sensor(s) hooked up to avoid an unintentional overheat condition.
