Had some time this morning to start it up, pulled fuel line at the vro pumped ball to make sure clean fuel and got a lot of oil until just clean gas,put muffs on turned battery on, pumped ball, while I was pumping ball with cowl off I saw fuel squirting from vro between the oiler and fuel side. Had someone pump ball so I could see exactly where the leak was but the ball was hard and no more leak. Decided to start anyway with my same procedure. Turn key on until beep and lights go off , no advance of the throttle, turn key to start count to three then push primer count to three and fire for a second, then key again no primer and she fires, all is well except vro leak
