Have a 93 Crusader 454XL. It has an ignition toggle switch with a starter button. When I turn the switch on, the starter engages then cuts out when the engine starts. I do not have to press the starter button. I have disconnected the power wire from the switch to the button, taking the button out of the loop and it still starts. What would cause this and why would the starter cut out after the engine fires? If I disconnect the yellow/red wire from the solenoid, the starter does not engage but I can hear the fuel pump running. This should not happen. Could it be the oil pressure switch for the fuel pump? I'd think if that would fail, it would fail open not closing the circuit to the fuel pump? It's just a mystery why it would engage and cut out when it starts. It's not the ignition switch because I swapped it with the working one from the port side.
