brian_from_boston
"Was finishing up the final co
"Was finishing up the final coat of Sikkens on the teak today and decided to take the 1988 29' Blackfin with Twin 454's to the fuel dock(my marina has a $.10 discount on Thursdays, today I would have paid $3.45 a gallon). The Port motor fired right up. The Starboard engine alarm did not sound with the key turned, starter would turn or engage either like there was no power. I went down to the breaker panel and found the starboard breaker when in the on position the indicator light was not lit. I tried the battery test and found the port to read 14 volts and the starboard 0. I just ran the boat a week prior (12 mile run) and had no trouble. It has been plugged in to shore power for the past 2 weeks with battery charger on. I did remove the negative from the starboard battery this week when trouble shooting another problem and noticed a blue/green crystalization on the exposed copper wire and female connector. In removing the negative, could the ground been on its last legs and I finished it off?
I didn't have the volt meter with me to check the battery posts for voltage however I did slice into the sheath and exposed about 3 inches of wire and the crystalization continued through, almost like cancer. I was able to break off the battery connection on the end, it was very brittle. I am going to replace the ground wire regardless.
Would this crystalization impede the battery from presenting a charge?
I never thought of this but the starboard motor can't start off the port battery?
Is there anything special for marine use or should I just use the automotive batter connection protective coating?
Once I straighten this issue out, I will be installing the floscans I asked you guys about earlier."
