I have a SP-A upper with a 290DP lower that is getting stuck in gear and wont shift out into neutral.
The first time problem occurred, I could not shift from forward to neutral. After 30 minutes of playing with the shifter and restarting and cutting off the engine, all worked fine for the next few minutes and shifted through all gears fine until after about the 6th shift it stuck in reverse.
Ultimately I disconnected all shift linkage to the upper drive and had to use channel locks to turn shift lever to neutral. This should rule out the reverse lock since it was still locked up after the linkage was disconnected from the drive.
I put everything back together and all shifting worked fine on trip back to ramp and went through multiple gear changes to get on the trailer.
The next time I took the boat out, I checked shifting ability on the hard without engine on and all worked well. I then backed trailer in and tried forward and neutral under power before pulling off of the trailer. Of course it then failed again stuck in reverse after clearing the dock.
Any suggestions on where to start? I've looked at the repair manual and nothing jumps out with an AHA moment on what the problem is
