surfs_up_today
"I have a pair of 2.5 year old
"I have a pair of 2.5 year old crusaders (270 hp, 350 CU IN blocks). On the starboard engine, the rpms are going up and down on the tach (tach is bouncing), the engine has lost about 90% of its power and it backfires. It happens intermittently. It is rock solid and I can cruse normal (about 3500 rpm)then goes into this mode. When the tach is bouncing, the engine is not really changing the rpm, just the tach…can't get the engine over about 2000 rpms, actual. Also, the base of the distributor itself is very hot to the touch with the engine off (unlike the good engine, which has a warm...not hot distributor). Same thing happened last year, but the engine finally died completely and the dealer replace the distributor assembly. Worked fine for about 150 engine hrs. What is up? Any ideas? In addition to fixing the problem, I go offshore fishing and need the reliability."
