jasonmac23
Hi all! I'm new here and I am fairly new to the outboard motor world as well, although I am not new to working on stuff myself, nor am I afraid to dig into a project. Up till now I've always had inboard ski boats.
Background: I recently bought an '84 Harris Pontoon wit an '84 Chrysler 45hp on it. I have taken the lower unit completely down and replaced all of the seals and installed new impeller. Now that I have put the lower unit back on the motor and ran it I've noticed a ton of white smoke coming out of the motor. Now I do also know, from seeing first hand. That the cylinder gasket is leaking, along with the exhaust plate gaskets. So I know this can cause water to get into the cylinders causing smoke. I also know that improper gas mixture can cause that as well, once I get new gaskets put in I am going to check my fuel ratio and give it a fresh mix. But my question is, when I put the new impeller in, which was the proper impeller for this motor going by part # like for like, it only fit by curving the fins back in the opposite direction of rotation. Is that normal? I was under the impression that it would fit to where the fins would come out flush to the inside of the pump housing?? So could it be too tight of a fit with the impeller that is causing the smoking as well?
