I have posted more than 13,000 times at Team Talk- don't worry about it.1. Crank engine : done. A little water came out...good idea
2. Remove Raw water hose from hull side of cooler : done . That's the same place where I connect a custom pipe to anti freeze bucket
3. Plugs : out and in bag
4. I'll keep boat in water , only a few days sub zero .
I realize I'm asking a lot of questions and don't want to over stay my welcome with you , you have been super helpful and it's appreciated, ive made notes of everythingyou've told me ..............Could you give 1 more comment on my plan to remove thermostat and run anti freeze 5 gallons for a minute or so ?
Again, if you drain the block, and I would do that any time I run anti-freeze through, the intake manifold won't have water in it so using the raw water pump to draw it in will get it to where it needs to be. It's also best to remove each plug after, to make sure it comes out in the color of the anti-freeze. That way, since you used the raw water pump to pull straight anti-freeze in, you don't need to disconnect the hoses.
I would leave the boat on the lift UNLESS you have temperatures below freezing for more than a day. The rule of thumb used by the last dealer WRT Winterization warranty is: if the temperature has been 32 or lower for three days, no warranty because there's no way to know if it froze and since the boats are brought inside for all Winter work, any ice in the engine will probably melt by the time someone starts, especially if additional work is needed.
