Garrett0123R
Hi, I recently purchased a 2003 Mercury 2 stroke (International) 15hp (15ML) which has been sitting up for a few years. Cleaned the carburetor and it starts right up. Put new spark plugs, and new foot oil. It starts and idle's fine. Rev's up in neutral with ease. I put it on the water and it ran good for a while. It then started bogging down like the carb jets were getting clogged. I then took apart the carb and cleaned it very well. Put the carb back together and ran perfect for about 10 seconds and now back to running poorly. What should I Do? Can It still be a fuel problem? I cleaned the carb and all the fuel lines plus the fuel filter.
Sometimes I can get the motor to run hard enough to get on top and then it sputters and slows by itself. I can have the throttle wide open and although it stays running it like the motor is in turtle mode.
Can this be related to the coil by chance?
