Cliff,
Rebuilt the carb for me and it is on its way back. Looking forward to getting it installed and see how it runs.
He found quite a few issues with carb. Here is his response to my inquiry regarding the condition of the carb.
"Ned, a few minor issues. No gasket between the carb and plastic spacer.
Power piston arms were bent, which would throw the calibration off considerably, one engine back richer or leaner than the other. Wrong fuel filter, too restrictive. Bottom plugs leaking fuel directly into the engine all the time. Wrong needle/seat assembly, from a cheap kit, WAY too small for a big block Marine application. The pump didn't have the latest design
seal on it for ethanol. Warped slightly across the front, so I machined
the airhorn flat for a better seal at the gasket.
They discontinued the heated choke coils about a year ago, and we currently do not have a supplier for them. There are still some available from what I've seen. Might have to check around a bit to find one......thanks....Cliff"
Thanks]
Ned
