I agree with Mark.
Let's start with the differences between a Std LH rotation SBC engine and a REV RH rotation SBC engine.
The wrist pin offset will be oposite (very important).
The camshaft profile will be correct for the reverse rotation.... it may be chain driven, or it may be twin gear driven.
If chain driven, the cam will follow crankshaft rotation.
If twin gear drven, the cam will remain rotating in the Std rotation... although the profile will be for a RH rotation.
If chain driven, the helical cut on the both the cam drive gear and the distributor driven gear will be special for this rotation.
When all is said and done..... the oil pump and distributor will rotate in the same direction as the Std LH engine.
The front and rear seals will be unique for REV RH rotation.
And of course the starter motor will need to be correct for this rotation.
#1 cylinder will always be the Forward-most cylinder...... doesn't matter which engine.
Firing order always begins with #1 cylinder.
As Mark said.... the SBC firing order now changes from the Std LH of 1-8-4-3-6-5-7-2 to the REV RH of 1-2-7-5-6-3-4-8.
When you place the spark plug wires into the distributor cap, you'll still begin with #1, but #1 will now be followed by #2, and so on.... and in a CW direction from #1..... same CW direction as the Std LH rotation engine.
TDC markings will be the same, since #1 TDC is #1 TDC all day long.... (but it gets tricky here)
While strobing the timing marks, instead of seeing your ignition advance lead away to the Stdb side of TDC, it will now lead away to the Port side of TDC.
IOW.... just oposite!
Since the Std LH engine timing tab does not offer but a few degrees in this direction, your best bet will be to mark off the balancer up to approx 35* in the oposite direction.
IOW, just oposite of this Std LH rotation balancer.
Now you'll use the tab's ZERO notch
only for any and all timing.
Your BASE advance should be the same as is with the LH engine.
Your progressive advance and your total advance should also be the same.
Basically, this REV RH rotation engine won't know that it's turning oposite from standard unless you tell it.
Just to be clear.... engine rotation is determined as though viewing from behind the flywheel end of the engine.
