Can anyone tell me if I need a distributor with a reverse cut gear for my Port 1987 454 Crusader. It is the motor with the firing order that statrs 1,8 and so on. I think some folks call it a standard rotating motor and some call it a left hand rotating motor. Thanks---- Update, went back to boat and pulled the Starboard distributor out and it has the same gear on the end as the Port. Could someone explain how the motor that rotatesin a different direction rotates the rotor in the same direction as the Starboard motor? I am sure there is an easy explanation for it, but I have not figured it out. When i bought the new distributor for the Port motor they asked me if it rotated opposite from the Starboard motor, I said yes and thy told me I needed a reverse cut gear on the distributor. It is the opposite rotation as the one I took out!
