Brand new and I believe it is? Thank you for responding !Clutch isn't fully engaging and more rpm causes it to finish
Are you using the correct gear lube and when was last time lube was changed?
Thanks!Check adjustment procedure for reverse... Remove back cover and check for full motion of shift rocker arm.
