Rectifier
DKelsey
Hello! I have a 1990 Evinrude xp 150 E150stlesb that is not charging. Upon inspection I noticed a red wire going towards the starter solenoid from the rectifier. Does this wire connect to the battery cable terminal on the solenoid? Thanks in advance!
Well, it’s been a hot minute since I’ve been on here. I apologize for taking so long. I did a compression test and I’m a bit concerned now. Compression ranges from 74-85 psi. Seems extremely low.
Test with a quality gauge.-----Or pull a few bypass covers and look at pistons and rings.-----These motors are famous for broken rings.
