I still have a couple of minor nagging issues which I have in separate threads below, I will come back and close those out. All told, I've put 41 hours on the rebuilt 8.1's and wondering if I should be concerned about the oil consumption. I might have mentioned this in a prior post, I have a feeling I wound up idling these at home a little longer than I should have. I pulled one plug and the cylinder wall didn't have a shine to it which is good (concern would be cylinder glazing).
I'm just wondering how long the entire break in process takes? I seems like I'm topping off constantly but I'm also checking at the beginning and end of each trip so it "feels" I'm wearing out the dipstick:
- over the first six hours, I used 1 QT on STB and 1.5 QTS on PORT. I did my 1st oil/filter change at 9 hours. Since then, (another 32 hours) I have added a total of:
STB - 2.5 QTS
PORT - 1.75 QTS
Does that seem excessive? Should I run the harder/closer to WOT for longer periods of time? Everything I've read about cylinder glazing says that if it's already an issue, there's nothing you can do at this point. I just don't know if a marine engine needs a much longer break in period than say a car where you can rack up the miles. Even though I have roller cams, my first start was around 2,000 RPM's for around 20 mins and varying RPM's. I had a bunch (6?) of quick runs to test various issues but they never idled for more than a few mins and I always revved them up/down. I'm doing another oil/filter change now and will log everything again.
Maybe they just need more time, curious what you guys think.
Bob
STB - 2.5 QTS
PORT - 1.75 QTS
Bob
