Pros and Cons for Closed cooling systems
S
Sony Fischer
Guest
Dear All
I am trying to fi
Dear All
I am trying to find pros and cons for freshwater closed cooling systems on Mercruiser Sterndrives kept in saltwater? I appreciate any help that you may give to help me decide whether I should purchase an engine with a closed cooloing system.
a engine with closed cooling
a engine with closed cooling system is the only way to go for frash water or salt water.
I dont see any cons with a cl
I dont see any cons with a closed system. The extra maintenance required is very little compared to the benefits. Aldo
" Sony, Marv and Aldo. My Mer
" Sony, Marv and Aldo. My Mercruiser dealer stated that closed cooling systems for V6 and V8 motors require a seperate through-hull raw water pickup (and pump?) to work properly. The 4 cylinder motors may use the stock outdrive water pump. With the closed cooling system, the risers still use raw water for cooling. "
" Chris,
That's the way i
" Chris,
That's the way is Done......
And Yes, It's the Only way to Go..... "
