OK, drop the lower and using your finger smear a little grease on the water inlet rubber in the top cap, install guide tube. pour some soapy water to lubricate the impeller , lock drive in FWD gear by turning the prop CCW while turning the splined shaft CW .Try not to move the prop. insert lower and line up copper water tube in guide tube. push drive up, turning the prop CCw about an inch to line the splines up,
Heres the tricky part, install the front nut by a few threads to hold the lower in place. align the upper brass shoe with the lower splined shaft in a straight line bow to stern. push drive up and hand tighten the nut some more. Install side nuts and tighten them carefully watching the shoe so it dosent bind up and make sure in goes into the upper half.Tighten side nuts fully, install remaining nuts, trim tab AND OIL
