mpt
My brand new engine rebuilt short block is a '96 V6 4.3 ltr Chevy Marine /Volvo/OMC with the stamped steel oil pan.
The oil pressure gauge reads a steady 40 lbs when turning the oil pump rod with a power drill. I still can't get any oil to squirt out of the rockers? Keep in mind that I am performing this step without the intake manifold.There is a steady flow of oil coming out of a port inside the distributor hole that shoots up out of the distributor hole and into the lifter valley between the heads. I've turned the crank 1/4 turn at times and still no results. Even before first attempt, I only snugged the hydraulic lifters down. Then later I went ahead and torqued them to factory specs of 40lbs. I still got no results! Should I install the distributor to re-direct the flow? How would I be able to turn pump then? Install intake manifold? Could I be rotating pump in the wrong direction? I washed and blew out all push rod holes even, maybe lifters might be plugged up?
