I have a 98' yamaha 225 and I have recently had to put quit a lot of money in it to try to get it water ready. Anyways right now I'm stuck . The motor is getting fuel and fire, but not cranking. I took the fuel bar off and faced away from the engine and had someone to turn over the engine, all 6 injectors sprayed fuel. After putting the fuel rail back on I pulled 2 plug wires, one at a time and the plugs were firing. The only thing that I'm not sure of is that I had the wife up front to turn the key on for say 3 sec. and turn it back off, then repeated twice, I then checked the little valve stem by pushing in the little valve and fuel would spray out. But if I wait 10 sec. before pushing in the valve then no fuel would come out ( seems as if it would loose it's prime). Of coarse I really don't know anything about the function of the valve stem set-up but I thought I would mention that cause I'm at the point to where I'm stuck. Oh by the way I can crank the engine by using a spray bottle with mixed gas in it, and it will stay running for as long as its getting gas. Guys Please help me out here, thanks
