ericulvila
I'm running a remanufactured 60HP Jonson model year 1992. During the break period I had the overheat alarm go off a couple times. One time it went off while I was in reverse for a few minutes.
It also will run hot on the earmuffs. At idle in the water it seems to be fine. around 100 degrees during arm up. I also have taken temps on it while running. Usually runs at 125-130 just off idle after warm up under load in gear.
