"was winterizing the boat and
"was winterizing the boat and the overheat alarm started to sound. I had already run on the hose, changed the oil and outdrive lube. Restarted and made sure the engine was up to temp again (170* F). Disconnected water line and connected to 5 gallon tank of antifreeze. Antifreeze was being drawn into the motor but after about 2 gallons the alarm began to sound. Even though the alarm was sounding the antifreeze was still being drawn into the motor. I was using the quicksliver flush muffs connected to antifreeze tank via 5/8" ID hose.
Does anyone see why the alarm would sound on this set up? Is it possible that the impeller is still working but not not up to par?"
