Over heating Alarm
uneakfshrmn
I have a 1999 70hp Evinrude outboard and the S.L.O.W. warning buzzer sounds after it runs for a little while. Thermostat is good and plenty of water going thru the motor. The sensor was replaced not long ago. Any suggestions
When's the last time the water pump was serviced ??
Last fall before I stopped using it. If I let it run the alarm stops but red light stays on. Water comes out the back and is cold, I took the thermostat out and put it in a bowl and as water got warmer it began to open so I now it works.
Disagree. I also have an overheating issue. Narrowed it down to my port side thermostat. Put both thermostats in a pot of water and even though they both opened the bad one opened at a higher temperature. Don't assume it's good just because it opens, check what temperature it opens at.
