Re: over heating
I'm going to guess you meant water going into the t-stat housing and coming out.
Where do you see it going or think it's going ?
Hold the long hose that comes in from the transom to the t-stat housing straight up, take it off the t-stat housing.
Start the motor with water going to the drive. How high it shooting ? 3 seconds quick shut off the motor.
Say you got good water to the t-stat, then it's down stream the clog, Remove the riser.
Riser good clogged up maybe ? If not or you had to replace it , look down the exhaust tube, got a flapper stuck half brokin in the exhaust ?
Get back to us i for one want to know the outcome, or you need more info.
