Re: Over heat with smoke
you would see smoke if the rubber tube that connects the riser to the exhaust tube melted, that happens everyday.
Ok Ready to test it ?
The long hose that comes in from the transom goes where, to t-stat housing ?
Or to a heat exchanger? Ether way disconnect it at th t-stat or exchanger, put water to the drive start the boat and hold the hose straight up, should have 12 inch's shooting up do it for 3-4 seconds and shut off the motor.
Good water there then it's down further the problem, no good water coming out the hose it's the impeller.
You forgot to mention what drive, alpha the impeller is in the drive, bravo it's engine mounted.
Ok so say you replace the impeller cause it's bad, or the impeller is good cause of the hose test you got to figure whats clogged.
If the hose goes into a heat exchanger, then that could be clogged, or the t-stat is bad or frozen closed. So say you replace the t-stat cause it's bad or you find you have those dreaded little check balls and they stick all is good to the riser, then maybe the riser is clogged.
But be aware getting the rubber to melt on the risers, you also probably melted the shutters/ flappers clean off now that maybe clogging your exhaust.
Only way to know is pull the risers or with the drive off looking up the exhaust hole.
Say you find the impeller is toast and there is nothing left i wouldn't be surprised if you melted the whole water pump housing.
Do the test then work from there.
No matter what your in for a couple of day's work in the least.
May the force be with you .
