................ I noticed orange antifreeze in the engine bed
Jim, was this anti-freeze, as in Ethylene Glycol.... or as in the RV type anti-freeze????
RV water system anti-freeze is pinkish/orangish.... and is sometimes used in engines and exhaust systems during layup.
and the antifreeze tanks for both engines are empty.
What are you calling an "antifreeze tanks"? Coolant expansion/recovery reservoirs... or the Heat Exchangers?
If the recovery reservoirs are empty, you'll want to find out why.
If the Heat Exchangers are empty, this is not a good sign.
1... did someone inadvertantly drain down the E/G side of the cooling system while winterizing???
2... did the antifreeze not serve freeze protection, and did you suffer engine block freeze damage???
No problem prior years but this year temps. were -25 to -40 for 3 months straight so I think something froze and popped.
Was your coolant good for -25 to -40 degrees???
Was it tested prior???
