leiniemann
"I have twin 5.7L, 270HP, 1978
"I have twin 5.7L, 270HP, 1978 Crusader motor. RH rotation has about 1200 hrs. and LH has about 400 hrs. In the last six weeks or so the RH motor has started using oil at the rate of about quart in a 30-45 cruse, running at 3500 RPM’s. There was a slit valve cover gasket leak, but I have replaced that. There are no major oil leaks that I have seen. I checked compression, and it ranges from 128 to 130 on one side of the motor (which was the last side checked and it had cooled a bit) and 130 to 140 on the other. Compression numbers sound fine to me. I did have an issue with water in the fuel at one point this summer, but after I emptied the fuel and water out of the filter it ran fine. About 75% of the time it is run at 1500-1800 RPM’s, the rest of the time I do not exceed 3500 RPM’s. Any suggestions as to what to look for are appreciated. Owners manual calls for 10W-40 and that is what I have always run, this is the third year I have had the boat.
Thanks"
Thanks"
