I have a 2005 four winns with a 5.0 GL VOLVO. The boat is new to us. The oil pressure reads 80 psi when ignition is on but not started. ( drops to about 30-40 when off) It also reads 80 psi when started. A boat mechanic replaced the gauge but still reads 80. I checked the ohms at the sending unit and off the engine it reads 250. Installed it reads 250 but when key ignition is on, it drops to 33 ohms (making the gauge read 80 psi) I have tried a new sending unit with the same results.
Just for reference, I hooked a mechanical gauge to the engine and it reads 50 psi at idle and increase as the rpm’s do.
Boat mechanic says the older anolog gauges read inaccurate and nothing can be done. ( I just have to live with it)
Any insight on this???
