Chaserman3
1985 aeto v4 yamaha 115hp, hard to start and backfires when i rev a little bit.
I unplug bottom plug wires when running and it doesnt change anything, top wires kill it.
compression is even (100-105) and bores look the same in all 4 (worn but nothing too bad) with endoscope.
swapped top and bottom coils, no change
carbs went through. when i ran it i disconnected the linkage so i can throttle individual carbs so i know its not a problem with the carbs
inspected reed valves and they look fine.
Bottom cylinders are not dead, I started the engine with the top plug wires off gave it throttle and it started on just bottom cylinders, retest starting all 4, unplug wires and nothing...
im ordering a spark gap tester to see if it might be bad quality spark
