It seems odd that this would occur at the same time of the double filter gasket issue.
The two would appear to be non-related, IMO.
The crusader motor is electronic it has. No distributor what know please help the boss is starting to worry
This engine will still have a Camshaft driven oil pump system.
The SBC oil pump is a Positive Displacement pump, using twin counter rotating gears.
They rarely completely fail...... even when well used.
Given the distance from the oil (elevation) they rarely fail to prime.... much less, loose a prime.
Possible causes of failure:
Oil level lower than pick up tube screen.
Pick up tube has become dislodged from the pump body.
Collapse of by-pass/pressure control valve spring.
Pump's drive gear shaft broken/sheared.
Camshaft Drive system shaft broken/sheared.
I would also recommend removing the pump drive unit, and use the primer tool and electric drill motor.
This will rotate CW for either Std LH or Rev RH rotation engines.
Side note for anyone who would be doing this on a conventional SBC ignition system, I would recommend that you bring the crankshaft around to #1 TDC on Comp Stroke before removing the distributor....... perhaps even punch the distributor hold down flange and engine block.
This will help you during initial re-indexing...... followed by re-setting timing.
