Have an issue with my 4hp outboard , a few weeks ago I was out on the dingy and had to slow right down to idle and it cut out and wouldn’t start again but started about an hour later,this happened a few times, so since then I have changed the fuel filter, spark plug, took the carb out and cleaned it, tried it again in the garage starts with full choke and then runs great.
put it back on the boat but same problem, cuts out if idle is too low and won’t start again, I read another post about fuel getting into the oil and thought the dipstick had a smell of gas so I replaced the fuel pump I’ve also installed an external tank since then so it had less chance of running out of gas. But same problem , thought about buying a new carb but don’t know if a new carb needs adjusted or not? Any advice would be appreciated thanks
