Need exploded view
dlh9350
I am trying to find an explode
I am trying to find an exploded view diagram of the lower gear case for a 1973 johnson 65 hp.
"<[img]"http://www.marineengin
Hey do you have a list of what
Hey do you have a list of what the part numbers are they coincide with the numbers on this diagram??
"I should get a raise!----
Ref # Part # Parts Description Qty SA Note Footnote
0386169 0386169
Add to pick list G'CASE ASSY, Complete std 1 7 Not Shown
0386170 0386170
Add to pick list G'CASE ASSY, Complete long 1 7 Not Shown
1 0385560
Add to pick list GEARCASE & BRG ASSY 1 7
2 0382343
Add to pick list BEARING, Pinion 1 2
3 0317652
Add to pick list SET SCREW, Bearing 1 7
4 0385515
Add to pick list OIL PUMP ASSY 1 7
5 0120052
Add to pick list LOCKWASHER 4 4
6 0307175
Add to pick list SCREW, Housing 4 4
7 0308120
Add to pick list SCREW, Screen to valve hsg 1 4
8 0383784
Add to pick list SCREEN, Valve housing 1 4
9 0318569
Add to pick list PLUG 1 6
10 0385516
Add to pick list COVER & PIN ASSY 1 6
11 0202136
Add to pick list PIN, Housing 1 4
12 0318603
Add to pick list RETAINING RING 1 6
13 0314034
Add to pick list SPRING, Pressure relief 1 7
14 0314035
Add to pick list BALL, Valve shift 2 6
15 0318568
Add to pick list GUIDE, Ball 2 7
16 0382408
Add to pick list THRUST BRG ASSY, Rev 1 2
17 0313448
Add to pick list PIN, Clutch dog 1 2
18 0313454
Add to pick list SPRING, Clutch dog pin 1 7
19 0386282
Add to pick list PROPELLER SHAFT ASSY 1 7
20 0318304
Add to pick list GEAR, Reverse 1 3
21 0313453
Add to pick list RETAINER PLATE, Brg hsg 1 4
22 0313445
Add to pick list RETAINING RING 2 4
23 0313446
Add to pick list ''O'' RING, Propeller shaft 1 1
24 0384603
Add to pick list BEARING HSG ASSY 1 7
25 0382407
Add to pick list NEEDLE BRG ASSY 1 2
26 0379504
Add to pick list NEEDLE BRG ASSY 1 3
27 0310600
Add to pick list OIL RETAINER 2 7
28 0316564
Add to pick list SCREW 4 7
29 0317178
Add to pick list SEAL, Screw 1 1
30 0302325
Add to pick list SCREW, Solenoid cover 4 3
31 0313339
Add to pick list NUT, Pinion to driveshaft 1 2
32 0313343
Add to pick list PINION 1 7 Available in complete gear sets only 55 & 60 hp 1968-71 use 397494 for 65 hp1972 use 397492, 65 & 70 hp 1973-75 use 397490 70 hp 1975 & later use 397338 Available in complete gear sets only 55 & 60 hp 1968-71 use 397494 for 65 hp1972 use 397492, 65 & 70 hp 1973-75 use 397490 70 hp 1975 & later use 397338
33 0314082
Add to pick list GASKET, Solenoid to g'case 1 2
34 0385068
Add to pick list THRUST BEARING, Pinion 1 3
35 0385092
Add to pick list DRIVESHAFT ASSY, Std 1 6
36 0385093
Add to pick list DRIVESHAFT ASSY, Long 1 7
37 0313754
Add to pick list ''O'' RING, Driveshaft brg 1 2
38 0385087
Add to pick list BRG HSG & SEAL ASSY 1 4
39 0318223
Add to pick list OIL RETAINER, Driveshaft 2 7
40 0319545
Add to pick list SCREW, Hsg to gearcase 4 4
41 0307551
Add to pick list PLUG, Fill & drain 1 1
42 0311598
Add to pick list WASHER, Nylon 1 1
43 0316981
Add to pick list TRIM TAB, Gearcase 1 7
44 0313715
Add to pick list SCREW, Trim tab 1 2
45 0385756
Add to pick list COVER ASSY 1 4
46 0318372
Add to pick list ''O'' RING, Shift rod 1 1
47 0318308
Add to pick list BUSHING, Shift rod 1 7
48 0313656
Add to pick list SEAL, Gearcase inner exh 1 7
49 0318303
Add to pick list SHIFTER, Clutch dog 1 3
50 0313447
Add to pick list THRUST WASHER, Rev 1 4
51 0385567
Add to pick list GEAR ASSY, Fwd 1 7
52 0314175
Add to pick list SCREEN, Water intake 1 2
53 0316484
54 0317230
Add to pick list THRUST WASHER 1 3
55 0317231
Add to pick list SHIM, .002'' 0 7
56 0317232
Add to pick list SHIM, .005'' 0 3
57 0385043
Add to pick list THRUST BRG ASSY, Fwd 1 3
58 0317165
Add to pick list THRUST WASHER, Fwd 1 6
59 0318544
Add to pick list SCREW, Plug gearcase lower 1 1
60 0385523
Add to pick list SHIFT ASSY, Gearcase 1 7
61 0309731
Add to pick list ''O'' RING 2 4
62 0317856
Add to pick list VALVE, Shift assy 1 7
63 0317858
Add to pick list CYLINDER, Shift assy 1 7
64 0317859
Add to pick list PISTON, Shift assy 1 7
65 0317860
Add to pick list CAP, Piston 1 7
66 0317863
Add to pick list SCREW, Plug 1 7
67 0317864
Add to pick list PIN, Push rod 1 7
68 0554545
Add to pick list ''O'' RING, Small 1 4
69 0385521
Add to pick list PUSH ROD ASSY 1 7
70 0317908
Add to pick list SNAP RING, Plunger 1 7
71 0317905
Add to pick list PLUNGER 1 7
72 0385953
Add to pick list SHIFT ROD & BRG ASSY 1 7
73 0318575
Add to pick list SPRING, Detent 1 7
74 0316506
Add to pick list BALL, Detent 3 1
75 0318250
Add to pick list CLAMP, Seal, core to shift rod, long 1 7
76 0318249
Add to pick list GROMMET, Exh hsg to shift rod, long 1 7
77 0314502
Add to pick list COTTER PIN, Propeller nut 1 1
78 0314765
Add to pick list GUIDE, Water tube 1 3
79 0314008
Add to pick list GROMMET, Water tube 1 3 Contents of Water Pump Repair KIt
80 0313815
Add to pick list IMPELLER HSG, Gearcase 1 7 Contents of Water Pump Repair KIt
81 0302820
Add to pick list SCREW, Impeller housing 4 7 Contents of Water Pump Repair KIt
82 0305762
Add to pick list SEAL 0 3 Contents of Water Pump Repair KIt
83 0307708
84 0552968
Add to pick list SCREW, Gearcase to exh hsg 4 4
85 0306314
Add to pick list LOCKWASHER, Screw, long 1 3
86 0313697
Add to pick list SCREW, G'case to exh long 1 4
87 0306470
Add to pick list LOCKWASHER, Screw, short 1 3
88 0306503
Add to pick list SCREW, G'case to hsg short 1 4
89 0317236
Add to pick list PLATE, Impeller housing 1 6
90 0382547
Add to pick list IMPELLER ASSY 1 2 Contents of Water Pump Repair KIt
91 0553127
Add to pick list ''O'' RING, Driveshaft to c'case 1 7
92 0308928
Add to pick list KEY, Driveshaft to impeller 1 1 Contents of Water Pump Repair KIt
93 0318841
Add to pick list THRUST BUSHING ASSY 1 7
94 0315810
Add to pick list SPACER, Propeller nut 1 1
95 0385098
Add to pick list COVER, Impeller housing 1 7
96 0318223
Add to pick list SEAL, Impeller housing 1 7 Contents of Water Pump Repair KIt
97 0314503
Add to pick list NUT, Propeller 1 2
98 0204027
Add to pick list SCREW, Cover to impeller 2 7 Contents of Water Pump Repair KIt
99 0317922
Add to pick list SEAL, G'case cover to shift rod, long 1 4
100 0317920
Add to pick list SHIFT ROD, Std 1 7
101 0317921
Add to pick list SHIFT ROD, Long 1 7
102 0383160
Add to pick list PROPELLER, 14 x 9 1 4
102 0382761
Add to pick list PROPELLER, 14 x 11 1 3
102 0382762
Add to pick list PROPELLER, 14 x 13 1 7
102 0382763
Add to pick list PROPELLER, 13-3/4 x 15 1 7
102 0382764
Add to pick list PROPELLER, 13-1/4 x 17 - std 1 7
102 0382765
Add to pick list PROPELLER, 13 x 19 1 7
102 0382766
Add to pick list PROPELLER, 12-3/4 x 21 1 7
102 0384140
Add to pick list PROP, 13-3/4 x 21 - 2 bl brz 1 7
102 0384144
Add to pick list PROPELLER, 13-3/4 x 15 - sst 1 7
102 0384141
Add to pick list PROPELLER, 14-3/4 x 21 - 2 bl bronze, cupped 1 7
102 0384139
Add to pick list PROPELLER, 13-7/8 x 17 - sst 1 7
102 0384142
Add to pick list PROPELLER, 13 x 19 - sst 1 7
102 0384702
Add to pick list PROPELLER, 12-3/4 x 21 - sst 1 7
103 0314188
Add to pick list CONVERGING RING, Aluminum 1 4
103 0315850
Add to pick list CONVERGING RING, Bronze 1 6
103 0319432
Add to pick list CONVERGING RING, Lexan 1 7"
