My 25 has a cold
I've soaked and rebuilt bo
I've soaked and rebuilt both carbs and at idle it will sneeze and quit. Can't seem to adjust it to stop sneezing. Did I miss something? It's a 25eshp Yamaha.
Check your throttle plates bac
Check your throttle plates back off your idle screw and make sure they r both closed. Also check you air fuel mix screws should b at 1 and 1 half turn factory spec. Just a couple easy things for u to check
soaking carbs in cleaner is ba
soaking carbs in cleaner is bad!
you could have now caused an air leak in the throttle shaft
did you rebuild or clean?
