I have a 1986 Trojan 37 Sport Sedan. The engine seacocks are in a very strange place, aft of the enginesalmost right against the aft engine room bulkhead. You can't accessthe seacocks unless you lift the floor over each engine to get atthem. The genset sits between the engines so there is less than afoot between the aft end of the engines and the forward edges of thegenset. With the floors in place, if I stretch out my arm as far aspossible I'm still about one foot from the seacock lever. This makesno sense at all. So my plan is to move them along with the seastrainers to the front of the engines. Lots of room there to crawlin and around the far side of the engine even with the floor inplace. I'm wondering if anyone else has done this?
The only thing that I'm wondering aboutis that the inside hull area where the seacocks are now, appears tobe almost an inch thinner. An area of about 12in. x 12in. is sort ofstepped down right around the seacocks. I'm wondering if that'sbecause the hull is too thick to screw the thru hull fitting into theseacock threads on most bronze thru hulls of the day because theymight not have been long enough? That sounds like a stretch, but whyelse would the hull be thinner right there?
I'm planning on using Marelon for mythru hulls and seacocks. I believe the Marelon countersunk thru-hull1-1/2” 250 series is 3” long. The backing plate material isabout 1/2” thick so hopefully the thru-hull fitting should be longenough in the area of the hull forward of the engines where the hullappears to be about 1” thicker than where they are situated now. Does anyone know the bottom hull thickness of this boat? Is anyonefamiliar with the area around the seacock being about one inchthinner?
Thanks for any and all replies
Cheers
Cheers
