Motor cuts when throttle forward
ndavison
"I have a '79 115 hp Evinr
"I have a '79 115 hp Evinrude motor. I can get it started with some difficulty ( it can take many tries), but once running when I shift to forward the motor cuts out. Any thought on what could be causing this?"
"Hi N Davison,
If you are new
"Hi N Davison,
If you are new to this motor, get the service manual, check for spark, compression and a clean fuel supply (inc. carbs) to get the fundamentals eliminated then troubleshoot beyond there if your problem is greater.
OB"
"when i boght mine (11579t
"when i boght mine (11579tlr,johnson) it did the same thing so i removed the carbs and cleaned them and the prob was resolved. there is also an idle adjustment on your linkage.
a shop manual is still a must, though i havent got my hands on one yet i will."
