Model recognition help please
rallycinq
"Hi Everyone, Newbie here who,
"Hi Everyone, Newbie here who, by dint of an unpaid debt has aquired a Fletcher speedboat with a Suzuki outboard.
Can anyone please advise how I find out which engine I have so that I can get an operation manual for it.
Its got a silver grey casing, power tilt, and I can't work out how to get the top off (I have the same problem with women).
TIA
David"
motor should have a serial# on
motor should have a serial# on the right side standing behind the motor right where the bracket mounts to the boat.
getting the top off is like snapping fingers reach around her back grab the bra strap and pretend you are snapping your fingers then she will have the top off
"Thanks for that, I'll be
"Thanks for that, I'll be back at the Loch later this week, in the meantime I'll need to find a young lady to practice my bra snapping technique.
Regards
David"
"That I can now do.
Its a D
"That I can now do.
Its a DT65 then 06502 xxxxxx
Managed to get the top off too. The front lug thats the catch should catch is broken, but that only held on with two 6mm bolts, so should be easily replaceable.
One difference between a woman and an outboard. The outboard doesn't change its mind after you've taken its top off.
Next issue.
The power trim is only clicking, not pumping. The motor was stored in the up position and I managed to lower it by using the pressure release valve.
I presume that there is some sort of relay set in the head of the pump, and it looks like two screws holding that on.
I momentarily kicked the starter, and the engine is not seized, but I think I'll want to do an oil change in the leg and a fuel filter, if one exists before turning it over anymore.
Any other suggestions?
Thanks folk
Cheers
David"
"Further investigation today,
"Further investigation today, and its not looking good. I removed the motor assembly from the top of the trim pump, and found emulsified oil everywhere.
While leaving that to drip I traced the power cables from the battery to the solenoid. mmmmm, bare wires wrapped round a bolt, and not done up too tightly either.
I forgot my claw wrenches, so when I go back the week after next I'll remove the pump completely and clean out and take my crimp pliers and sort the wiring.
Happy days.
Cheers
David"
