fishwhenyoucan
Hello All. I am new to the forum. In years gone by I fished alot and had kids, fishing slacked up some. This year I bought a 1988 Bass Buggy 20' Pontoon at what I thought was a good price and it came with a 1988 Merc 60hp. Motor runs out great, starts easy, compression was off slightly (120, 105, 118) and I assumed it might be from not having been run and after just a bit of running it did even out some. The main problem is when I take it to the lake, if you get above 3800 RPM in just about 15 seconds the water pressure gauge pegs out and the overheat alarm goes off and stays on until you throttle down and then it will go off and water pressure returns to about 10 - 15. I had the motor tuned, carbs rebuilt, impeller and gaskets replaced, foot lube changed and checked for leaks. A few notes, the shop doing the work thinks the motor is raising up at higher RPM and is sucking air causing the pressure issue and the overheat problem. Someone down the line trimmed the transom a little bit to lower the motor. I have been told all kinds of stuff from "it's a short shaft motor" which it is a 20" long shaft, to it needs a poppet valve (shop told me this model does not have thermostat or poppet valve). It has what appears to be smaller than normal prop (numbers on prop - A10 P9). The transom could be lowered some more (1- 2 inches) but the motor does fine at lower RPM and the water from the telltale is a steady stream during all of this. Can anyone help? Right now this is frustrating as this shop said well you just need ro run it below 3900 RPM all the time.
